OUTPUT ERROR: ReferenceError: "myinfotable" is not defined.
xiaoqw
sorry, If I say I want to change Numeric entry widget to property display widget based on your AddRow Services, how should I make changes in AddRow services. I think I need to insert infotable in Datashape and also in AddRow Services.Is it right way to finish this function? Could you give me some suggestions?
Related post
xiaoqw
(To:xiaoqw)
Hii, when I refresh on your mashup page, grid widget will auto-generate a new row, which is empty. When I keep refresh the page, it will generate many empty rows in the grid widget. Sorry for disturb you. I really want to figure it out. thank you.
xiaoqw
(To:xiaoqw)
Sorry, I still have a problem. Because I need to insert target line compared with your value. but when I add one more field in datashape and want to show it in label chart, the target number cannot show in label chart. only for value. Could you do me a favor how to display target value in the labelchart? thank you
xiaoqw
(To:xiaoqw)
