Permissions while connecting C-SDK to ThingWorx.
ysb
7-Bedrock
7-Bedrock
Hi Team,
I have a device connected to a remote Thing by using an AppKey (DefaultAppkey) with no permissions (The associated User has no permissions). What I'm trying to do is:
- To use that DefaultAppkey only to have the device connected to the Thingworx (appearing in the Unbound Thing List), so that I can create a Remote Thing, a new User (DeviceUser) and Appkey (DeviceAppKey) (with specific permissions to run services and read/write remote properties)
- After completing the last step, I want to send that new DeviceAppKey to the device through a remote service (Let's call it SendAppKey_Service) and set some Remote properties.
I've made a service to create all these Entities, using EntityServices, set the remote properties and run the Remote Service to send the DeviceAppKey to the device (Let me call it CreateDeviceEntities_Service).
That CreateDeviceEntities_Service is called from the Thingworx side, by an Administrator User, once the device appears in the Unbound Thing list (connected using the DefaultAppkey ).
I can run the CreateDeviceEntities_Service on thingworx side as Administrator but both SendAppKey_Service and setting remote properties just don't work.
I've already tried to run everything step by step and manually, and I can't set the remote properties (it allows me to change its value but once I refresh the properties, it returns to its original value)
and the SendAppKey_Service doesn't run properlly.
Even when the Remote Thing is created, I have that error message in the C-SDK logs:
[ERROR] 2019-07-19 12:15:02,806: twMessaging::handleMessage: Response ID 6 has code 160: Entity DeviceThing.T does not exist or is not yet associated with a Thing
[ERROR] 2019-07-19 12:15:02,806: twSubscribedPropsMgr_PushPropertyInfoList: Error pushing properties for DeviceThing.T.  Error: 1110.
[ERROR] 2019-07-19 12:15:02,806: twSubscribedPropsMgr_PushProperties: error pushing or persisting property list, code: 1110
What would be the best way to implement this workflow ?
Is it possible o set a remote property value and run a remote service while using an Administrator User in the Thingworx but having the device connected through an AppKey with no permissions ? In that case, am I supposed to get permissions errors in the Thingworx Log ?
Note: I'm using ThingWorx 8.4.2. and ThingWorx Edge C-SDK-2-2-3-1545 running in the device.
Thanks in advance.
PaiChung
22-Sapphire I
(To:ysb)
The initial connection with the default appkey will be a connection only, there won't be context I think for the Admin user process to send a command back to the device that way.
If you give the default appkey perhaps permissions to run a specific registration service, it can pick it up that way.
PaiChung
22-Sapphire I
(To:ysb)
Looks like you are missing visibility permissions for the new appkey user?
Everything else looks ok I think.
Registration could btw be initiated upon connection from the device side as well so you don't have to monitor for connected devices on a continuous basis.
ysb
7-Bedrock
7-Bedrock
(To:PaiChung)
Hi @PaiChung ,
Thanks for your fast reply.
The new appkey user is working fine, I'am having problems with the default appkey (initial one with no permissions).
Considering your answer, any appkey user will need at least a visibility permission to allow connection between the device and the remote thing, is that right ?
Thank you very much.
PaiChung
22-Sapphire I
(To:ysb)
