I placed a Pie Chart in a Responsive container, but the Height of the Legend takes around 30-40% of the container; how can I Decrease it?
Thinworx Version: 9.3.0
Hi @Shashi_Preetham.
There doesn't appear to be a way to do what you would like. I suggest posting a request on the ThingWorx Ideas board.
--Sharon
So, @slangley,
Isn't there a way, as of now, some workaround? I am in contact with PTC Support too, but there isn't a solution as of now?
Hi @Shashi_Preetham
In our preliminary testing, we weren't able to find a way to do what you wanted. If you've opened a case, please send me a private message with the case number so I can track it.
Thanks.
--Sharon
I tested in both a 9.1 platform and 9.3.4 with adding a pie chart and couldn't replicate;
9.1;
9.3.4;
I did have to make the container static to make the pie chart this "small" though. But even with it as responsive the legend stayed this size and only grew in width.
I have attached the things I used for my test in case you want to check it out.
Values I used in my infotable;
Not sure if this is helpful at all, but hope you can get something out of it.
Jens
