Popup shadow
krishnakomal123
Popup shadow
There is a shadow background of popup.Any options to disable it as It effects the look of UI?
1 ACCEPTED SOLUTION
Try the following custom CSS in the mashup from where you open the popup:
.mashup-popup {
box-shadow: none !important;
border-style: solid !important;
Probably, you need to adjust the borders after removing the shadow.
Hope it helps,
Raluca Edu
.mashup-popup {
Hope it helps,
Raluca Edu
