PostJSON in ThingWorx 9.0 Extension SDK
nmilleson
Has anybody been successful using the ContentLoader functions in TWx 9.0 Extension SDK?  I've been following this example and this javadoc but I keep getting a null pointer exception.  Just to test my sanity, I used the same url, header, and content information inside a Composer service and I was successful.  I've attached the stack trace and the code I'm using is:
public Boolean myService() throws Exception {
	Boolean verify = false;
	ContentLoader verifyCheck = new ContentLoader();
	String url = "https://postman-echo.com/post";
        JSONObject content = new JSONObject("{\"meta\":{\"key\": \"" + "abc" + "\"}}");
        String username = null;
        String password = null;
        JSONObject headers = null;
        Boolean ignoreSSLErrors = null;
        Boolean withCookies = null;
        Double timeout = null;
        Boolean useNTLM = null;
        String workstation = null;
        String domain = null;
        Boolean useProxy = null;
        String proxyHost = null;
        Integer proxyPort = null;
        String proxyScheme = null;
        try {
           _logger.warn("URL in myService(): " + url.toString());
           _logger.warn("Content in myService(): " + content.toString());
        verifyCheck.PostJSON(url, content, username, password, headers,
          ignoreSSLErrors, withCookies, timeout, useNTLM, workstation, domain, useProxy,
          proxyHost, proxyPort, proxyScheme);
        catch(Exception e)
        	StringWriter sw = new StringWriter();
        	PrintWriter pw = new PrintWriter(sw);
        	e.printStackTrace(pw);
        	_logger.error("Exception in myService(): " + sw.toString());
		return verify;
@slangley ,
Thanks for the reply.  I believe I found the issue.  In the example that I linked, all of the Boolean values are set to null.  I changed them all to false instead and that seems to have fixed the issue.  The PTC example may need to be updated.
5 REPLIES 5
slangley
23-Emerald II
(To:nmilleson)
Hi @nmilleson.
We're working internally to answer your question and will respond back as soon as we have more information.
--Sharon
@slangley ,
slangley
23-Emerald II
(To:nmilleson)
Hi @nmilleson.
Thank you for the follow-up!
I will pursue getting the instructions reviewed for update.
--Sharon
slangley
23-Emerald II
(To:slangley)
Hi @nmilleson.
The article you referenced has been updated.  Please mark the appropriate response as the Accepted Solution (even if it's yours) for the benefit of others in the community.
--Sharon
Thank you!  Much appreciated
