Problem property ShowDataLoading for some Widget.
For some WIdget this property not working.
When I select this property for some objects, I do not see the icon that I'm saying is loading the data.
The platform in use is 7.2.0 & 7.2.3 and the widget are :
Progress Gauge
Shape
Time Series V2
and both Slider Vertical & Orizontal.
Thanx
Giuseppe Fiore
Giuseppe Fiore : I observed similar behavior with Gauge and Label widget when binding data coming from services fetching high volume of data. Could you please confirm the data been loaded as sometime the data loaded is very quick and there is no icon appearing even when ShowDataLoading property is checked for the widget.
Issue has been raised with R&D Team under internal reference # PSPT-3718 .
-Durgesh
To test the operation of the property I created a service that only returns a value, but with a wait within the 10 seconds service, but despite the amount of data being really low, the icon does not appear.
// pause():INTEGER
var milliseconds = pause(3000);
var result =milliseconds
The Icon Does not appear into GAUGE,SLIDER,SHAPE ....
THNX
Giuseppe Fiore
Thanks Giuseppe, I have updated internal Jira ticket raised with R&D for all widgets having this behavior under reference # PSPT-3718.
-Durgesh
There are a News on this issue ?
How can I track the status of my request?
thnx
Giuseppe
