Problem for following the tutorial:'Creating Remote Thing'
강형민
Hello.
As starter, I followed the the Thingworx tutorial.
In this course, I have a problem for 'Setting the Remote Vending Machine Simulator for Remote Things'
Following the steps in the video, I generated the RemoteVendingMachine.
But, 'isConnected' Attr is False.That's why I can't bring the data.
Do you know the reason for that?
supandey
(To:강형민)
Hi, what sort of device are you attempting to connect to the ThingWorx could you also share which EDGE sdk you are using to connect your Edge device to the ThingWorx's Thing
BTW, do you by any chance see your Edge device in Monitoring > Status > Remote Things > Unbound
Sushant Pandey​ I followed the tutorial 'Setting the Remote Vending Machine Simulator for Remote Things'. So i used the EDGE which thingworx gave.
Anyway, I succeeded after tring many times. But the reason is undiscovered.
