Programmatically adding things with identifier problem
I'm trying to create 8 things and bind them each to a different identifier. For the identifier I'm using a simulator which creates 8 identifiers which look like SN000i. (e.g SN0000 , SN0001...). </div><div>The problem is that the SetIdentifier() method is not working for me. I'm using TW 5.4 </div><div><br></div><div>Here is the code:</div><div><br></div><div><div>for( var i = 0 ; i<8; i)<br></div><div>{</div><div>var params = {</div><div> tags: undefined /* TAGS /,</div><div><span class="Apple-tab-span" style="white-space:pre"> </span>thingTemplateName: "RemoteThing" / THINGTEMPLATENAME /,</div><div><span class="Apple-tab-span" style="white-space:pre"> </span>description: undefined / STRING */,</div><div><span class="Apple-tab-span" style="white-space:pre"> </span>name: "Car"i /* STRING */
Resources["EntityServices"].CreateThing(params);
Things[params.name].EnableThing();
Things[params.name].RestartThing();
var ident= {
identifier : "SN000"+i
Things[params.name].SetIdentifier(ident);
