Is there a way to change Mashup tags via script?
I have several (~40) Mashups which need a tag removed.
Chad,
Assuming that you are referring to ThingWorx scripting, in the current 3.2 version you cannot 'directly' script to a Mashup. In theory you will be able to do the following in 4.0:
var params = {
tags: undefined /* TAGS */
Mashups["<MashupName>"].RemoveTags(params);
...but as Ryan points out you could always use direct API calls in external scripts...this could even be facilitated in a ThingWorx script using the ContentLoader Resource Post functionality, although we don't consider it best practice to call a ThingWorx API (via URL) from within a ThingWorx script.
