Properties from Thing Shape
svisveswaraiya
Is there a snippet or service to fetch the list of properties in a thing shape to display as infotable? I tried the GetPropertyDefinition from the ThingShape but it returns empty infotable. I wanted to fetch all the properties defined in the thing shape. How can we achieve this use case?
Thanks in advance,
Shalini V.
There isn't an easy way to do what you want.
I think it will have to be something like a GetPropertyValues on the Thing and then some filtering or looping through to build your final infotable.
You can look into using Categories potentially.
