Hi All,
I am having Thing 1 and Thing 2. Both the Thing having different properties. I have to dynamically plot properties curve from both the Thing in a same graph (Chart). Is there any solution for this use case?
Sathishkumar C.
Hi Sathish, you could probably create an infotable in which you can pull the data from both the things and then you can query this infotable to return full set of data.
Or other option could be to create a dataTable that holds data from both the things's properties
Yeah your point is valid. But, Every time my selection (list of properties from different thing) will not be same. Selection will change dynamically. Then, how to assign data shapr for the infotable.?
Thanks & Regards,
Sathishkumar C
