Query and Group By
  • October 15, 2015
  • 4517 views
Greetings,
I have a requirement for storing some data in a Stream and then providing a service to query that Stream and aggregate the results by certain value columns.
For example, if i had a stream backed by a DataShape containing ID, NumericValue columns, and i wanted to rollup the numeric values to the beginning of each month (using the Stream Timestamp), is this even possible using the Query/filtering API?
Best answer by paic
Use Query to get your slice of data and then use Aggregate (InfoTable Functions) to get the roll up.
paic1-VisitorAnswer
rtaylor-31-VisitorAuthor
Thanks Pai. I'll give it a try.
Yep....worked. Thanks.
