Hi i'm SeonHo
I want to store Thing's data in a stream or a valuestream.
Is there a limit to storage?
For example, if each device stores about 10,000 data per day in a common stream, is there a storage limit?
Does it slow down when I load data through a query and display the graph?
thank
Hi Seonho, If each device stores 10k/day data points, you will have to care a lot about storage, working with this ammout of data isn't easy on any way ( starting on showing it on Mashups/Graphs ).
Thanks regard
I will store and remove the stream data separately every month.
So, are there any other good suggestions for viewing logs of data?
