tried to install the Thingworx-Foundation-8-2-1 under Ubuntu according to the descritption : https://support.ptc.com/WCMS/files/174097/en/Installing_ThingWorx_8.2_1.0.pdf . I got stuck at page 32, points 2 and 3: I can not find the files "thingworxPostgresDBSetup.sh" and "MED-61111-CD-074_F000_ThingWorx-Platform-Postgres-8-0- 0.zip". Where can I download them ?
That should be referring to the Install files you download from support.ptc.com as far as I can tell.
So if you have the proper subscription, once you go to Download software, into Thingworx you should see those versions available to you (H2 Postgres MSSQL etc...)
I downloaded it from https://developer.thingworx.com/resources/downloads . There is only download for thingworx foundation. Where are the other ones ?
Depending on your subscription with PTC, all your downloads can be found in support.ptc.com
if I try "Download Software" on support.ptc.com it says I have no access with my account. What is the sense to state you can download a trial version if you can not download important parts for testing ? I am trying to set up a ThinigWorx Server for days already and nothing works. Is there a version we could set up within an hour ?
Moreover I still did not see any documentation how to connect to it with the studio.
Best Regards
Andras Horti
Andras,
If using the trial edition 120 day download, you should follow the installation guide here...
https://support.ptc.com/WCMS/files/174119/en/ThingWorxTrialEditionGuide8.2.pdf
The other guides are for the full subscription versions. The downloads noted there are only available after a subscription is purchased.
Additionally there is a Studio Trial version with it's related document...
http://support.ptc.com/WCMS/files/170678/en/StudioGettingStarted.pdf
Thank you,
Adam
I can't access this link
It says that my account is not authorized to reach this link.
