Questions about the Thingworx-Foundation-8-2-1 Ubuntu Installation
ahorti
3-Visitor
tried to install the Thingworx-Foundation-8-2-1 under Ubuntu according to the descritption : https://support.ptc.com/WCMS/files/174097/en/Installing_ThingWorx_8.2_1.0.pdf . I got stuck at page 32, points 2 and 3: I can not find the files  "thingworxPostgresDBSetup.sh" and "MED-61111-CD-074_F000_ThingWorx-Platform-Postgres-8-0- 0.zip". Where can I download them ?
6 REPLIES 6
PaiChung
22-Sapphire I
(To:ahorti)
That should be referring to the Install files you download from support.ptc.com as far as I can tell.
So if you have the proper subscription, once you go to Download software, into Thingworx you should see those versions available to you (H2 Postgres MSSQL etc...)
ahorti
3-Visitor
(To:PaiChung)
I downloaded it from https://developer.thingworx.com/resources/downloads . There is only download for thingworx foundation. Where are the other ones ?
PaiChung
22-Sapphire I
(To:ahorti)
Depending on your subscription with PTC, all your downloads can be found in support.ptc.com
a-horti
(To:PaiChung)
if I try "Download Software" on support.ptc.com it says I have no access with my account. What is the sense to state you can download a trial version if you can not download important parts for testing ? I am trying to set up a ThinigWorx Server for days already and nothing works. Is there a version we could set up within an hour ?
Moreover I still did not see any documentation how to connect to it with the studio.
Best Regards
Andras Horti
AdamR
(To:a-horti)
Andras,
If using the trial edition 120 day download, you should follow the installation guide here...
https://support.ptc.com/WCMS/files/174119/en/ThingWorxTrialEditionGuide8.2.pdf
The other guides are for the full subscription versions.  The downloads noted there are only available after a subscription is purchased.
Additionally there is a Studio Trial version with it's related document...
http://support.ptc.com/WCMS/files/170678/en/StudioGettingStarted.pdf
Thank you,
Adam
I can't access this link
It says that my account is not authorized to reach this link.
