I have a customer using Thingworx 8.5 on Linux with Postgres and using a temporary license,
They can create things using the composer, no issues, but whenever they try to create a thing using the REST API, they get an error saying that "LICENSE IS NOT INSTALLED", as you can see attached,
Please, any ideas?
Tks,
Chris
Hello Chris,
I have not tested this with a temporary license. Please review my settings and compare to your Postman configuration.
Transaction:
POST http://<IP Address>:<port>/Thingworx/Resources/EntityServices/Services/CreateThing
In the Headers Tab
In the Body Tab
The value for the AppKey is from ThingWorx "Browse -> Security -> Application Key -> <keyname>"
The AppKey needs to be associated to a user which has the privilege to create things.
Let me know if this helps.
Peter
Hello Chris,
Transaction:
In the Headers Tab
In the Body Tab
Peter
