Hi, I did an export of my mashup from version 4.2.0.15 to 4.2.0.35. All the radio button widgets are gone from the visual layout but they are still listed under the Widgets tree structure. When I tried to select the radio button from the tree structure, the property pane still contains other widget name, so I cannot delete the invisible radio button widgets from the tree structure. could you please let me know what I can do to cleanup these invisible radio buttons?
Hi Luwen,
The widget in question is the Generic Radio Button extension or the default Radio Button?
– Adam
I believe it is the default Radio Button. Please let me know is there something I can do to remove them or appear?
Luwen,
I was able to reproduce this issue and found that reimporting the Mashup will resolve it. It appears you need to import the State Definition before the Mashup that uses it.
Adam
Thank you very much for that. I will do that.
