Hi ,
I want to delete and add rows in grid with Custom service using selected Rows property of grid. i have infotable service which is returning infotable with Datashape.
how to use selected rows and delete the rows from grid?
Hello @KB_9398319
You can achieve this by writing a custom service.
Please refer the following community post which provide answer to your query:
https://community.ptc.com/t5/ThingWorx-Developers/Add-row-or-delete-rows-from-Grid/m-p/705129#M49724
Om Dukiya
You can also add a boolean property into the datashape, and make the property editable in the grid. When you try to delete the selected rows, use this property as filter option.
Hi @KB_9398319,
If your question has been answered, please mark the appropriate response as the Accepted Solution for the benefit of others in the community.
Regards.
--Sharon
