Read file properties
smajumdar
2-Explorer
I want to read a file from the Thingworx server which is being send from a device every 5 mins. I need to read it and display the columns in a mashup. Can anyone help me how to do this.
3 REPLIES 3
You should look at FileRepository services, this Uploaded files should reside on a FileRepository thing.
Aanjan
(To:smajumdar)
Soumya, what sort of properties are you looking for? Basic ones like name, size, type etc? Once it is on your repository, as Carles mentioned, you can use a service like 'GetFileListing' on your Repository Thing to display the file with its properties.
smajumdar
2-Explorer
(To:Aanjan)
Hi Ravi,
I want to to read the text.log which will be sent from a remote device every 5 mins. I have to parse the below 4-5 properties from the file. The structure is shown below.
04-Jul-2016 17:03:06.422 INFO [main] RESULT=        3-SFU
04-Jul-2016 17:03:06.422 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Server built:          Jun 9 2016 11:16:29 UTC
04-Jul-2016 17:03:06.422 INFO [main] COMPLETED=         06/22/2016 07:15PM
04-Jul-2016 17:03:06.422 INFO [main] SPControl v=               10.0.8
04-Jul-2016 17:03:06.422 INFO [main] CURRENT_LOG_CSF3=            250
04-Jul-2016 17:03:06.422 INFO [main] UPLOAD_COUNTER=          28
04-Jul-2016 17:03:06.422 INFO [main] LAST_APPLICATION_FILE=             C:\Test\test.txt
04-Jul-2016 17:03:06.422 INFO [main] LAST_UPDATE==           04-Jul-2016 17:03:06.422
among these I need to find out the values for RESULT=, COMPLETED= , SPControl v= etc
