Hello ThingWorx Community!
I started receiving this error message "Error occurred while validating HTTP header: referrer" and I haven't been able to find much online in regards to what could be causing this error or the possible solutions to correct it.
Any information or guidance pertaining to what causes this error message and how I should go about fixing it would be greatly appreciated!
Thank you!
Jennifer Dorcey
What is your ThingWorx version? You may try stopping tomcat, then removing these two files and starting the tomcat again:
And as a quick follow-up, it may also refer to this problem:
We are currently using Version 7.1.2 with plans to upgrade to Version 8.0 in the next few months. We also start this via an appKey and have never used Form Logins before so we don't think that is the cause of the error we are receiving.
I believe this is a bug fixed in 7.2. Tomorrow during the US office hours I can find and give you the exact jira number and fix versions.
That would be great, Thank you!!
Actually, just looked it up. Should be fixed in TW-2815, latest version of 7.2.
