Remote Datatable returns GetCurrentUser inconsistenty
SS_11298241
7-Bedrock
I’m working on a project where I need to access the GetCurrentUser from a remote DataTable. However, I’m facing an issue where the returned values keep changing after each execution. Specifically:
  • When the logged-in user is Gail, the DataTable shows both Gail and IOCL.
  • When the logged-in user is IOCL, it shows both IOCL and Gail.
I’ve attached the files for reference, but I would appreciate your help in identifying what might be causing this issue. Could you guide me on what I might be doing wrong?
@SS_11298241
the reomte service calls GetCurrentUser on target server and returns the configured "Publish As User" in FederationSubsystem, it does not return login user of target server.
as you configured 2 lines in  FederationSubsystem,  reomte service should return one of the two "Publish As User" randomly.
@SS_11298241
