@Velkumar How to use different repeaters in Mashup?
PFA the ZIP file for sample repeater mashup.
Velkumar R
Hi @PPrasad_IoT18,
You can use below link to learn about Repeater widget
https://www.youtube.com/watch?v=zXrKq1tvntU
Velkumar R
Hi @Velkumar
The video gave a basic idea.But, can you explain the types with some used cases examples?
Can you tell me your use case ? So that I can arrive some solution for you using repeater.
Velkumar R
Ok @Velkumar...I have a Report containing a list of parameters with values.
I need to display those out of limit values in a single Mashup by writing a Service.
Which repeater is to be used and how?
The Thing present is not importable. Throwing error. Please provide Thingtemplate also.
@Velkumar how to obtain the values of a JSON converted infotable in the mashup?
