Resources["ContentLoaderFunctions"].PostJSON调用大模型接口,短回复没有问题,长回复报以下错:javascript service. Message ::Read timed out。请问是不是系统又限制?在哪里可以更改配置?
Two timeouts need to be checked.
1) PostJSON functions has a timeout parameter with a default of 60 seconds
2) ScriptTimeout in platform-settings.properties: https://support.ptc.com/help/thingworx/platform/r10.0/en/#page/ThingWorx/Help/Installation/Installation/platform_settings_json_configuration_details.html
Hi @YY_14409369,
It appears that there is a reply that answers your question. For the benefit of other Community Members who may have the same question, it would be great if you could designate it as the Accepted Solution.
In the event that this response did not answer your question, please post your current status so that we can continue to support.
Thanks for using the PTC Community!
Charles
