Hi All
I am having a problem with moving between mashups.
I duplicated an old project and edited it, but when I select a button to move between my new mashup pages, it keeps referring to the old master "drop". I have changed this in every place I can find.
This is what is coming up in the URL:
Please help.
I am desperate.
Darryl
Hi
Thanks, I had done all of that.
I figure out the problem.
Apparently, when you copy a navigation button from another mashup it seems to retain some hard coding for a master, even when it is changed manually in the widget settings.
I deleted the navigation button and recreated it, and it is working perfectly.
Thanks for the help though.
Cheers.
Hi, Darryl.
You have set the Master Property on the new mashup to point to the new Master association you want it to use, is that correct?
Per the Masters section in the Help Center.
-- Craig A.
Hi
Cheers.
