I have an infotable with one row and column obtained from SQL query and want to retrieve this value as output of a service. How to get that value and what should be the basetype of it (Base type of output) ? Tried giving the base type as string and infotable but getting erros.Kindly help.
Hi Raj,
I'm not sure if you were in one of the training sessions we did, but we have a whole section that shows the CRUD interaction with a relational database. If you never went through that training, we recommend you attend either one live or the eLearning.
On the community site there is an older training video if you go to Support/Training (as well as the workbook) that should explain how you do this.
Hi Raj,
Please post the source code of your Service along with the error messages you are encountering when executing this Service.
Adam
