SAXParseException while making a POST call in thingworx
ptc-4108282
I am new to Thingworx. I am trying to make a post rest call from thingworx. Here is the script that I have written in the service of a thing.
var result = null;
var params = {
//proxyScheme: undefined /* STRING */,
//headers: undefined /* JSON */,
//ignoreSSLErrors: undefined /* BOOLEAN */,
//useNTLM: undefined /* BOOLEAN */,
//workstation: undefined /* STRING */,
//useProxy: undefined /* BOOLEAN */,
//withCookies: undefined /* BOOLEAN */,
//proxyHost: undefined /* STRING */,
url: Things["Windchilldemo1"].getRestUrl() + "/bac/import" /* STRING */,
content: "<?xml version=\"1.0\" encoding=\"UTF-8\" standalone=\"yes\"?><BACSpec xmlns=\"http://www.ptc.com/bac\"><Profile><name>newProfile</name></Profile></BACSpec>",
//timeout: 60 /* NUMBER */,
//proxyPort: undefined /* INTEGER */,
//password: undefined /* STRING */,
//domain: undefined /* STRING */,
//username: undefined /* STRING */
result = Resources["ContentLoaderFunctions"].PostXML(params);
At server side I have jaxb implementation for the XML structure. But it does not hit the url.
I am getting the following error.
Wrapped org.xml.sax.SAXParseException; lineNumber: 1; columnNumber: 10; DOCTYPE is disallowed when the feature "http://apache.org/xml/features/disallow-doctype-decl" set to true. Cause: DOCTYPE is disallowed when the feature "http://apache.org/xml/features/disallow-doctype-decl" set to true.
Is the value for "content" converted to JAVA object on server side?
Please guide me to resolve this issue.
Thanks in advance.
2 REPLIES 2
PaiChung
22-Sapphire I
(To:ptc-4108282)
You are able to make this call using something like Postman correct?
You may want to try as PostText first.
ptc-4108282
(To:PaiChung)
Thanks Pai for the reply.
There were minor issues on server side. I fixed those issues.
For the sake of simplicity I have taken a more simplified object structure.
message body in postman is
   "spec": "my<></>Spec",
   "deliveryUrl": "http://vagrant.ptcnet.ptc.com:2280/Windchill/servlet/rest/bac/import"
The result is as follows:
  "importReportContent": "my<></>Spec : http://vagrant.ptcnet.ptc.com:2280/Windchill/servlet/rest/bac/import"
In thingworx, The snippet in the service is like this.
var result = null;
var params = {
url: "http://vagrant.ptcnet.ptc.com:2280/Windchill/servlet/rest/bac/import" /* STRING */,
    content: { "spec": "mySpec",  "deliveryUrl": "myURL" } /* JSON */,
contentType: undefined /* STRING */,
// result: STRING
var jsonResult = Resources["ContentLoaderFunctions"].PostJSON(params);
result = jsonResult["importReportContent"];
This returns empty result without any error. I tried with providing a wrong url. then also I got empty result without any error. So it seems that the url is not being used. Please let me know if I am doing anything wrong or missed anything.
Behaviour is the same with PostText as well.
