Hi guys,
I have EMS and luaScriptResource (which is fetching data from sensors) running on one machine and Thingworx on another machine.I have configured the offline message store in config.json.
Now when I stop the Tomcat server the offline message get saved in offline_msgs.bin file and as soon as I start the Tomcat the server the file size becomes zero. How can I restore the messages/data from offline_msgs.bin file.
Correct me if I am wrong, offline_msgs.bin file store the data sent by sensor when the Thingworx is offline.
Suppose the TWX server is down for some time may be for 1 hr, can I restore all data send by sensor for that one hour?
OK got the solution,
I was using stream to log the properties, but I was using timer event to log the properties into stream hence data was getting lost.
Instead of timer now add subscription to data change event of properties.
