Hi Everyone,
I try to include infotable inside a infotable on a remote service. When I read it with sdk C, I have only the first infotable and the other has not row. someone know how to do it?
Remote service structure:
service name (testService)
input:
INFOTABLE (infotable1)
String (stringvalue)
Integer (intvalue)
INFOTABLE (infotable2)
String (stringvalue2)
Code C:
register_service(){
twDataShape * ds = 0;
ds = twDataShape_Create(twDataShapeEntry_Create("infotable1", NULL, TW_INFOTABLE));
twApi_RegisterService(TW_THING, thing_name, "testService", NULL, ds, TW_NUMBER, NULL, sendDataService, NULL);
//get parameter
enum msgCodeEnum sendDataService(const char * entityName, const char * serviceName, twInfoTable * params, twInfoTable ** content, void * userdata) {
int rc = 0;
twPrimitive *infotable1_prim;
twInfoTable *infotable1_info;
(void) serviceName; (void) userdata;//remove warning compile
if (!params || !content) {
fprintf(stdout, "sendDataService - NULL params or content pointer\n");
return TWX_BAD_REQUEST;
twInfoTable_GetPrimitive(params, "infotable1", 0, &infotable1_prim);
if (dinfotable1_prim != NULL && infotable1prim->length > 0)
infotable1_info = infotable1_prim->val.infotable;
// init command to send
if (infotable1_info != NULL && infotable1_info->length > 0){
twList *rowsinfotable1 = infotable1_info->rows;
if (rowsinfotable1 != NULL){
char * stringvalue;
int intvalue;
twPrimitive *infotable2_prim;
twInfoTable *infotable2_info;
if (rowsinfotable1->count > 0){
int i;
for (i = 0; i < rowsinfotable1->count; i++){
twInfoTable_GetPrimitive(infotable1_info, "infotable2", i, &infotable2_prim);
if (infotable2_prim != NULL && infotable2_prim->length > 0)
infotable2_info = infotable2_prim->val.infotable;
if (infotable2_info != NULL && infotable2_info->length > 0){
twList *rowsinfotable2 = infotable2_info->rows;
if (rowsinfotable2 != NULL){
char *stringvalue2;
if (rowsinfotable2->count > 0){
int i;
for (i = 0; i < rowsinfotable2->count; i++){
twInfoTable_GetString(infotable2_info, "stringvalue2", i, &stringvalue2);
fprintf(stdout,"stringvalue2: %s \n", stringvalue2);
twInfoTable_GetString(infotable1_info, "stringvalue", i, &stringvalue);
fprintf(stdout,"stringvalue: %s \n", stringvalue);
twInfoTable_GetInteger(infotable1_info, "intvalue", i, &intvalue);
fprintf(stdout,"intvalue: %d \n", intvalue);
Hello Craig,
Thanks for your answer.
I found the issue. It's was not on C sdk structure but on the server twx himself. I don't know why but one of my properties inside INFOTEAM had a type UNKOWN instead of INTERGER. I recreate this properties and my service works well now.
Regards
Simon
Hello, Simon.
Based on the article https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS226131 you'd use twPrimitive_CreateFromInfoTable to create the nested infotable to start with. Can you verify that's how the infotable was created?
-- Craig A.
Hello Craig,
Regards
Simon
