SSL/TLS MQTT
smarino
SSL/TLS MQTT
Hallo.
I would like to connect my Thingworx platform 7.2 with a MQTT broker in a secure mode SSL TLS.
I’m using ActiveMQ 5.3 as MQTT broker and MQTT Thingworx extension as connector.
I successfully tested the connection without SSL mode.
However, I could not implement secure mode connection.
  I have made two changes to activemq.xml file.
a) Instead of line
<transportConnector name="mqtt" uri="mqtt://0.0.0.0:1883?maximumConnections=1000&amp;wireFormat.maxFrameSize=104857600"/>,
I used
<transportConnector name="mqtt+nio+ssl" uri="mqtt+nio+ssl://0.0.0.0:8883?maximumConnections=1000&amp;wireFormat.maxFrameSize=104857600"/>
b) I added
<sslContext>
<sslContext keyStore="file:${activemq.base}/conf/activemq.ks"
                             keyStorePassword="password"
                             trustStore="file:${activemq.base}/conf/activemq.ts"
                             trustStorePassword="password" />
</sslContext>
  1. Activemq.ks is a keystore containing the certificate I generated for the broker.
  2. Activemq.ts is a keystore containing the certificate I generated for the broker clients.
  I tested Activemq server with MQTT.fx client tool. I could connect in SSL/TLS mode, with TLSv2 protocol option and CA certificate keystore option, by importing the certificate broker client I made in keystore for MQTT.
My questions.
1)     Is my ActiveMQ configuration proper?
2)     Where should I put the broker client certificate in Thingworx side?
3)     Perhaps the MQTT Thingworx extension uses Tomcat to communicate to ActiveMQ broker? Following this assumption I modified the server.xml file of Tomcat configuration.
Below there is one of my unsuccessful tests:
a) I added this connector
               <Connector
                                            port="8443"
                                            protocol="org.apache.coyote.http11.Http11NioProtocol"
                                            maxThreads="150"
                                            SSLEnabled="true"
                                            scheme="https"
                                            secure="true"
                                            clientAuth="true"
                                            sslProtocol="TLS"
                                            enableLookups="false"
                                            keystoreFile="conf/tomcat.ks" keystorePass="password"
                                            truststoreFile="conf/tomcat.ts" truststorePass="password"
               </Connector>
Tomcat.ks is a keystore containing the certificate I generated for the broker clients.
Tomcat.ts is a keystore containing the certificate I generated for the broker.
I removed this line
<Listener className="org.apache.catalina.core.AprLifecycleListener" SSLEngine="on" />
4)     Instead of MQTT Thingworx extension, it is possible to use ActiveMQ extension for a secure SSL/TLS connection throw ActiveMQ?
Thank you for your attention.
Best regards,
    Sergio Marino
mchehaibi
(To:smarino)
Hi Sergio,
This might not answer your questions but have tried using the MQTT extension from the ThingWorx Marketplace ThingWorx IoT Marketplace ?
Best Regards,
Amine
Hi Amine.
Thank you for your replay.
My question is about MQTT extension of Thingworx marketplace.
Best regards,
   Sergio
I posted how to secure the broker: Securing the Mosquitto MQTT Broker
Hi Bruce.
I apologize for my delay.
I wanted to try your suggestions before answering.
Because I was involved in other tasks too, meanwhile, thank you very much.
    Sergio
