Is there a way to retrieve screen resolution information on mashup load using service or any other methods in thingworx?
Hello krishnakomal123,
At this i do not believe there is a way for the Mashup to retrieve screen resolution information from the Client upon load. As I am sure you are aware we recommend using Responsive Mashups which will automatically adjust the size of contained Responsive Widgets to match the Client's resolution. Please see here for more information.
