Could any one help with the java script to check whether the entered input (text box) contains special characters or not?
Thanks in advance,
Shalini V.
You could try searching online for javascript samples of the use case:
https://www.codeproject.com/Questions/234476/Javascript-to-Check-if-field-has-special-character
