Service error notification on a mashup
iguerra
Thingowtx 9.6.5
I know it's possible to show a message on a mashup if a service gives an error.
The message can be a fixed token on the available localizations, or a string.
The string can also report the [server-message] that is the string description of the error generated by the service (plus some additional text !), that is in this format
Error executing service ***SERVICENAME**** . Message :: ***ERROR DESCRIPTION *** - See Script Error Log for more details.
Showing "See Script Error Log for more details", but also "Error executing service" is not very professional, even more there is a "customer" reading that ... (which error log ??)
Moveover  I would show a dynamic text returned by the service (in case of error) as a "wanted behaviour" for the error notification, because there may be more conditions...
Is there a way to to that ?
For me it could be enough to show the error description only instead of the whole message. There should be something like [server-message-msg]
1 REPLY 1
Not according to my knowledge. What I do is wrap my “external” services code in try/catch and return data + error messages as an infotable, which I then handle via expressions on the mashup side.
Constantine
