Good day, all.
I hope you are well. I have a filter widget that filters through my stream. I want to take all the data in the stream and export it to csv I am struggling to write a service that does this. This link: https://support.ptc.com/help/thingworx_hc/thingworx_8_hc/en/index.html#page/ThingWorx/Help/Mashup_Builder/Widgets/DataExportWidget.html. Speaks of exporting passwords that are encrypted. It does not address my scenario.
Does anyone know how I can achieve this?
Many thanks
Hi ,
You can follow steps mentioned below:
1. Add Data Export widget to Mashup
2. bind output of service/filter of infotable type directly into data field of export widget.
3. Now on click of export button data will be downloaded in csv format
Hope this Helps!!
Hi ,
Hope this Helps!!
