Hi Developers,
When i login to the mashup through browser the JSESSIONID is set to all the thingworx services called during that session. Is there a way to add or set another cookie to those services?
I have checked the "Content Loader Function" resource and it only has "Get Cookies" service and nothing else for my use case.
Saran
My guess is you want to set the cookie in the user browser.
However the Thingworx server (and the collection functions) is server side not client side.
So to manipulate the cookie, you might be able to do it with the Expression widget, else some custom widget (basically one that functions like a client side 'extension' to the mashup capabilities)
I don't think the Expression widget supports the 'document' object through.
Hi @PaiChung,
Thanks for your reply.
I have used expression widget to manipulate services but not the browser cookies. Could you please elaborate how to use expression widget for our use case?
Saran
Again I think the Expression widget doesn't allow you to use the 'document' object
But otherwise here is a reference: https://www.w3schools.com/js/js_cookies.asp
