SetEntityPermission removes existing UserGroup permissions
Velkumar
Hi Community,
I'm trying to set RunTimePermission for project entities using below code
let params = {
	allow: true /* BOOLEAN {"defaultValue":true} */,
	name: "UG2" /* STRING */,
	includeDependents: false /* BOOLEAN {"defaultValue":false} */,
	type: "Group" /* STRING */,
	projectName: "TestProject" /* PROJECTNAME */,
	tags: undefined /* TAGS */
// no return
Resources["EntityServices"].SetEntityPermission(params);
When we execute this service it removes existing UserGroup permission from entity.
Is this a bug or I'm doing something wrong here.
TWX Version : 9.4.1
/VR
Rocko
(To:Velkumar)
have you checked using AddResourceEntityPermission instead?
Rocko
(To:Velkumar)
Velkumar
(To:Rocko)
Hi @Rocko
AddResourceEntityPermission works properly.
/VR
Rocko
(To:Velkumar)
Does that solve the issue for you? I mean SetEntityPermission expects all permissions to be included in the parameters and overrides existing values. To set individual privileges, use the Add and Delete services. You could create a case for clarification though.
