Setting Organization FormLogin options programmatically
mlähde
3-Visitor
Hi, community!
We have a Java extension that's creating a bunch of TW entities programmatically, among others a organization entity. Creating the organization entity, adding members to the organization, assigning permissions and setting the home mashup works as planned, but how does one set the FormLogin options programmatically? I'm talking about login prompt and login image, among others, that are editable through the Composer (see image). I've checked the API docs at http://support.ptc.com/help/thingworx_hc/thingworx_7_hc/ThingWorx_Core_Help_Center/baggage/javadoc/c... but couldn't find suitable methods.
We're using TW 7.3.4.
posipova
20-Turquoise
(To:mlähde)
Currently the only way to set up such FormLogin parameters is manually, through the Composer.
posipova
20-Turquoise
(To:mlähde)
Bummer! Thanks for the confirmation.
