Is it possible to set following fields dynamically in .NET SDK:
| [ThingworxPropertyDefinition(name = "Temperature", description = "Current Temperature", baseType = "NUMBER", category = "Status", aspects = new string[] { "isReadOnly:false" })] | |
| [ThingworxEventDefinition(name = "SteamSensorFault", description = "Steam sensor fault", dataShape = "SteamSensor.Fault", category = "Faults", isInvocable = true, isPropertyEvent = false)] |
Data fields I have are dynamic and are loaded from config file so it is not practical to use static statements. Does anyone know if these settings can be implemented to class constructor? I have read through the documentation but haven't been able create working implementation.
