Setting permissions to many things using a service.
  • April 19, 2024
  • 748 views
Hi all,
I am using the SetThingPermission service. The aim is to get about 10 things to have authorization to invoke the same services (about 7 services).
I do not know what the correct values to pass as parameters to SetThingPermission service to achieve what I want,
let params1 = {
entityName: "Thing_Name" /* STRING */,
entityType: "Thing" /* STRING */,
permissions: permissionsTable /* INFOTABLE {"dataShape":"RunTimePermissions"} */,
query: undefined /* QUERY */
Resources["EntityServices"].SetThingPermission(params1);
As per the above, the permissionsTable requires some fields that I once more do not fully understand how to fill. permissionsTable:
permissionsTable.AddRow({
isPermitted: true, // BOOLEAN
name: "GetAlertStatuse", // STRING [Primary Key]
resourceName: '', // STRING [Primary Key]
type: "Service", // STRING [Primary Key]
permissionName: "ServiceInvoke" // STRING [Primary Key]
This gives me an error. Does anyone know how to fill in these parameters?
Many Thanks.
Best answer by Rocko
Please check the DataShape "RunTimePermissions". The properties do have a description field helping with what is what.
Rocko
Rocko19-TanzaniteAnswer
