does would anyone know which service to use to set the visibility on an individual entity. If you could provide an example that would be great.
Currently I create networks, things and organisations and organisational units programmatically using data from a mashup. I would also like to be able to set the visibility of the things & networks at the same time, but can't seem to find a suitable service. I have seen discussions concerning 'collections' but I want to set it on an individual basis.
Kieron
Hi Kieron,
To set visibility of one Organizational Unit at Thing's level:
thing.AddVisibilityPermission({
name: "principalName", // -- like: "OrganizationName:OrganizationUnitName"
type: "OrganizationalUnit"
If you want to set it for Organization at Thing's level:
name: "principalName", // -- like: "Organization"
type: "Organization"
Hi Kieron,
Hi Carles,
that's the one, thank you for the quick response, you're a star.
Kieron
