I am getting a socket error when I try to import entities from file, which is strange as I am importing from a local file. Binary and xml return the same error. The app log only returns the 5 lines below. Any help is appreciated.
2019-08-20 17:42:16.193-0400 [L: WARN] [O: c.t.s.s.p.PlatformSubsystem] [I: ] [U: ] [S: ] [T: pool-13-thread-1] Thingworx System Metrics_-----------------------------------------------------------------$
2019-08-20 17:42:26.271-0400 [L: ERROR] [O: E.c.t.w.Importer] [I: ] [U: Administrator] [S: ] [T: https-jsse-nio-443-exec-6] [message: java.net.SocketTimeoutException]
2019-08-20 17:42:26.274-0400 [L: ERROR] [O: c.t.w.Importer] [I: ] [U: Administrator] [S: ] [T: https-jsse-nio-443-exec-6] Invalid request: org.apache.catalina.connector.ClientAbortException: java.net.Soc$
2019-08-20 17:42:26.274-0400 [L: INFO] [O: c.t.migration] [I: ] [U: ] [S: ] [T: https-jsse-nio-443-exec-6] Start post migrating from version [8.3.0] to version [8.3.0] ...
2019-08-20 17:42:26.274-0400 [L: INFO] [O: c.t.migration] [I: ] [U: ] [S: ] [T: https-jsse-nio-443-exec-6] Finished post migrating from version [8.3.0] to version [8.3.0].
Turns out it was an error from WSEMS on the client side that occurred after I upgraded from TW 7.4 to 8.1.
@clansdale I just wanted to follow up with you to see if previous response was helpful for your question?
If so, please indicate the appropriate response as the Accepted Solution for the benefit of other Community members who have the same question.
Vibhuti
