Community email notifications are disrupted. While we are working to resolve, please check on your favorite boards regularly to keep up with your conversations and new topics.
Do we need to install Manufacturing common building blocks before importing solution framework.
I can see pre-requisite as
Can anybody clarify whether common building block is 'mfg1-2' extension
I think you are following the "Installation Prerequisites" sections of TWX Solution Framework from below link.
https://github.com/PTCInc/twx-solution-framework/releases
I have not tested this. But I think you should follow the "6.Download the Building Blocks Using the Software Downloads Page" sectoin to install the latest version MFG-Common-1-2 (1 MB).
