I have a table with 2 records and 4 fields:
ID | Field 1 | Field 2 | Field 3
1 4 5 6
2 7 8 9
I want the values of the fields to be stacked on each other for each ID (x-axis).
I am able to achieve this with a Label Chart when I create DataField(1-3) with the Field(1-3) column names and set the XAxisField = ID.
When the with StackSeries = True and ChartType = Marker, everything behaves as expected, with the marks stacked on top of each other for the 2 different IDs. However, when I change the ChartType = Bar, the stacked bars appear to go way over the Y-Axis limit. It seems as if some weird scaling is going on that I can't understand. Can someone please re-create my scenario and let me know what I need to do in order to get the Label Chart with StackSeries=True to work with a ChartType = Bar? I am using Version 5.4.
Thanks!
-Matt
