State definition is showing value instead Display String
egolindano
7-Bedrock
Hi. Im trying to display a label based on a state. To achieve this I decided to create the next State Definition;
(Check attached image 1)
In the mashup that shows the value (with a ValueDisplay) I specify the state definition in the valueformat.
(Check attached image 2)
But, even when i do this, in the mashup still showing the value instead the Display String..  I also defined the labels on the widget, but it doesn't change anything..
Thank you in advance.
PaiChung
22-Sapphire I
(To:egolindano)
That display string probably would work for the 'button bar' but doesn't work in general for state based definitions.
So you may have to create images per state that show/read the way you want.
2 REPLIES 2
PaiChung
22-Sapphire I
(To:egolindano)
slangley
23-Emerald II
(To:PaiChung)
Hi @egolindano.
If the response provided by @PaiChung answered your question, please mark it as the Accepted Solution for the benefit of others with the same question.
--Sharon
