Hi
I have a requirement to store images into a Data Table and then to display the Image on a Mashup.
First of all, Is this a good approach to store images in a Data Table. Will there be issues when upgrading Thingworx?
I created a Data Table having image data shape in our dev box. I could add images from within Composer opening the Home Mashup and the adding values.
I would like to create a Mashup so that the user can add an image with other values into Data Table.
Appreciate your Help and Comments!
TIA
Saby
Better you store it on a FileRepository, for memory usage will be more efficient.
Thanks Carles
I am planning to store in File Repository like you mentioned. I am able to view the Images using LoadImage service. That's the reason I was planning to store in Data Table to be able to display the Images on a Mashup.
Sabarish
You can set the image widget with the image File Repository URL, then you just need to add on the Infotable the Image URL, not all the bits.
