I have installed KEPServerEX 6 in a windows computer. I am reading data from the PLC. I want to store some of the tag values in a SQLIte database running in a Linux server in the same network. I am aware of DataLogger to storing data from kepware to a database. I am storing data in a sqlite database in the local machine with help of DataLogger. But I need to store data in sqlite database which is present in a different Linux server. What are the possible methods are available for this. Please help.
Article - "How to log data to an external database with PTC Kepware Products": https://www.ptc.com/en/support/article/CS277795
Hello @DP_11006808,
It looks like you have a response from a community member. If it helped you solve your question please mark the reply as the Accepted Solution.
Community Moderation Team.
