Hey, I just followed this tutorial, to create a Stream storage, but I need to employ a Mashup to see the values.
My problem is how to do that knowing that the service to add Stream entry is not automatically called.
When I change the value of a thing and I don't launch the service 'Add_Stream_Entry_Services' Nothing is showed in the QueryStreamEntriesWithData test service.
I want to insert values in QueryStreamEntriesWithData service without clicking test service 'Add_Stream_Entry_Services' each time.
Thank you
It is ok I didn't call the function properly in my Mashup Data.
