I've got a Thing Template called 'NetworkSection' with three properties: 'StartPoint' a reference to another Thing, 'StartCity' a string, and 'Locations', an infotable with one column of Locations.
I've also written a subscription for NetworkSection on its own 'StartPoint' property, which updates the 'StartCity' and first row of the 'Locations' infotable', based on the properties of the new StartPoint.
me.Locations.getRow(0).Loc = Things[me.StartPoint].Loc
me.StartCity = Things[me.StartPoint].City
When I change the StartPoint of a NetworkSection from within composer, both the StartCity and Locations properties update as expected. However, if I do the same through the REST API, I'm finding that the StartCity updates, but record in the Locations infotable does not. Any ideas why that might be?
Hi @bmaxted would it be possible to share the REST call you are making to update the properties? Additionally, it will also be helpful to see if the applicationLog.log is showing any error related to the REST call.
May be you can try and debug it with Postman application.
