Hello Community!
After installing and configuring the TWX Azure IoT Hub connector:
Connector: 3.0
Thingworx: 8.5
I am traying to run the edge-device-demo, but I’m not able to see telemetry data sent by the simulated device from the demo.
Attached you will find screenshots:
Can you please tell me what I am missing?
DJ
Finally, I was able to run the demo and the telemetry data sent by the edge-device-demo. But now, I am trying to receive telemetry data of an IoT device, I am able to import the device from Azure, but I cannot see the device properties.
Is there a service that I need to run in order to get the properties and be able to see properties updates within Thingworx?
Looking forward to hearing from you guys.
You'll need to create those properties in your thing as remote properties. For example, if your message property is engineTemp, create a remote property in your Azure IoT Thing and set the 'source' to engineTemp.
