Tagging while creating an extesion
aluna
7-Bedrock
I am creating an extesion on java using the TW plugin, and I am creating some thingtemplates, I want to tag them but I do not see that option, can someone tell me if that is possible?
alexe1
(To:aluna)
Hi Armando,
What does your existing code look like to create your ThingTemplates? That might help provide some insight to what you are having trouble with.
aluna
7-Bedrock
(To:alexe1)
Hi alex, basically I used the  sdk documentation and just click on the thingworx perpestive and add a thing template and the code was generated automatically
here is what I have
package iQorSDM_v3_Extention;
import java.io.StringReader;
import java.util.Date;
import java.util.HashMap;
import java.util.Map;
import java.util.Map.Entry;
import javax.swing.text.Document;
import javax.xml.parsers.DocumentBuilder;
import javax.xml.parsers.DocumentBuilderFactory;
import org.json.JSONObject;
import org.slf4j.Logger;
import org.w3c.dom.NamedNodeMap;
import org.w3c.dom.Node;
import org.w3c.dom.NodeList;
import org.xml.sax.InputSource;
import javax.xml.xpath.XPath;
import javax.xml.xpath.XPathConstants;
import javax.xml.xpath.XPathFactory;
import com.thingworx.entities.utils.EntityUtilities;
import com.thingworx.entities.utils.ThingUtilities;
import com.thingworx.logging.LogUtilities;
import com.thingworx.metadata.annotations.ThingworxServiceDefinition;
import com.thingworx.metadata.annotations.ThingworxServiceParameter;
import com.thingworx.metadata.annotations.ThingworxServiceResult;
import com.thingworx.relationships.RelationshipTypes.ThingworxRelationshipTypes;
import com.thingworx.resources.entities.EntityServices;
import com.thingworx.resources.content.*;
import com.thingworx.things.Thing;
import com.thingworx.types.collections.ValueCollection;
import com.thingworx.types.primitives.StringPrimitive;
import com.thingworx.types.primitives.NumberPrimitive;
import com.thingworx.types.primitives.BooleanPrimitive;
import com.thingworx.types.primitives.JSONPrimitive;
import com.thingworx.types.primitives.XMLPrimitive;
import com.thingworx.types.InfoTable;
public class iQorSDMWrapper_TimeoutTemplateV3 extends Thing {
  public iQorSDMWrapper_TimeoutTemplateV3() {
  // TODO Auto-generated constructor stub
thearonh
(To:aluna)
I don't believe that there is a way to add tags through java code.
One way that I have used is to add the 'tags' aspect to the entity in the metadata.xml - here is an example:
<ThingTemplate name="myThingTemplate"  tags="Applications:MyCustomTag" ... />
Just make sure that the Tag library that you are using either already has the tag in it, or is set up to be dynamic.
Hope this helps.
