We are using ThingWorx 7.0.0 version. Trying to create extension in Java using the Java SDK.
We downloaded 2 files 1. TW_Download_Java_SDK.zip and 2. MED-61061-CD-055_M020_ThingWorx-Java-SDK-6-0-0-189.zip
We did not find the Java SDK for version 7.0.0.
Question 1) where to find the Java SDK for version 7.0.0.?
Question 2) When we used the above mentioned zip files when creating ThingWorx project in Eclipse (Mars), we are unable to create it. It says "The SDK location does not include the Thingworx SDK.".
Pavan
Pavan, the download is located under Download Center -> Order or Download Software Updates -> ThingWorx Platform -> 7.0.
Here is a link to a Knowledge Base article which expands on this.
The Eclipse Plugin wants the Extension SDK....not the Java SDK.
The Extension SDK can be found on the PTC support site(support.ptc.com).
It can be found under Software Downloads:
Thingworx Platform
Release 7.0
ThingWorx Extensions SDK
Thanks Brian for the response.
I am following this document:
"ThingWorx Extension
Development Guide Version 3.1 February 2016"
I have got the Eclipse plugin. It is installed. No issues there.
What I am facing issue is the next step where we create ThingWorx project. What I am looking for is "ThingWorx-Extension-SDK-[version]-latest.zip"
Version is 7.0.0 for us.
I could not find the 7.0.0 version of SDK that they are talking about in the document.
Pavan
For the Extension development, 'Thingworx-Extension-SDK-7-0-0.zip file should be used at this step. You can download the file from PTC downloads-> Thingworx Platform -> Release 7.0
Just an FYI, the java SDK you are trying to import is for Edge development.
Thanks Giri for clarification.
I am not able to locate PTC downloads-> Thingworx Platform -> Release 7.0
Please see attached image... I tried navigating to highlighted links. Could you please help locate it?
Thanks Ravi. I was able to download the software and create a ThingWorx project.
A quick update to this question...
The Extension SDK is now available on the ThingWorx Marketplace! Here's a link directly to it: http://marketplace.thingworx.com/Items/Extension%20SDK
...if that doesn't work you can simply search for "Extension SDK" or find it under "Development Tools"
